I've just put together a bike light using the Cutter tripple Cree PCB with 3 x Cree Q5 LED's. I'm using the Cutter supplied Khatod optics and the beam pattern is terrible.
Up close (3m say) against a wall the hotspot looks like 3 squares on top of each other, but not centrally, in a sort of line. At a distance you can't make out the edges of the squares unless you are looking for them but you do notice that the hot spot is elongated and not what you were expecting!
I've built up some other bike lights using the Leidil Rocket 3 optics (with Cree LED's) and the beam pattern is far far superior.
Anyone else notice this?
