I have a possible project which would probably require paralleling a lot of individual lithium laptop cells, like 9x 1.6ah unprotected cells in parallel and then putting 8 of these banks in series to meet the voltage requirements. This is necessary not only to increase the overall AH of the bank but to increase the current capabilities. Don't have a clear spec on how much current is required but it's probably around 6A average, 12A peak, far more than a 1C avg or 2C peak discharge for each cell.
I would be able to build a regulator to clamp each cell at 4.2V during charging. I'd feed the string a constant current at first and after the first bank hits 4.2V I'd fold back the current to keep the shunt reg's heat generation "reasonable", then shut off all the charging current when the last series bank hits 4.2V. I will also have the pack designed to shut off when the any of the parallel banks drops to 2.75V.
There is no other cell type I'd be able to use and stay within budget. Nor will it be practical or cost-effective to separate out these cells for charging independently.
I've seen laptop packs may parallel 2 or 3 cells inside. I know NiMH for example does not charge or even store correctly in parallel, one fully charged NiMH may take current from another one in parallel leading to one overcharged cell and one partially run-down one.
So my question is this. Are there any "gotchas" I'm missing regarding paralleling greater numbers of lithium laptop cells, such as parallel balancing issues, that become problematic when attempting to use many cells paralleled together with no way to isolate them? Another hypothetical problem would be cells of different impedance in a bank resulting in some cells bearing more current and discharging faster than others, yet this doesn't appear to be a real problem because if one starts to discharge more the open cell voltage drops would would soon shift current over to the higher resistance cells resulting in an even discharge.
