Hello there,
Since you are using an amber LS and running off of a
12v automobile system you will see resistor heating
due to power dissipation as high as 2.88 watts or even
more. This will certainly heat up a 3 watt resistor!
What i would recommend is to use two 100 ohm resistors
in parallel, each rated at 10 watts. This will not only
give you a higher power rating, it will distribute the
heat to two resistors instead of one. This means each
resistor only has to dissipate one-half of the total heat.
Since they are both 10 watters, each one will only have
to dissipate a maximum of one-eighth to one-quarter
of their rating, which is a very safe operating area indeed.
I dont think it's too bad of an idea to use resistors,
after all they are the simplest and most reliable drive
system. You wont find the regulation as bad as if you
were to drive from say a 6v system with the same percent
change in voltage.
Here is what you can expect from using two 100 ohm, 10 watt
resistors in parallel (50 ohms) for a battery voltage of
11.5 to 14.5 volts using an amber type LS LED (2.5v):
1. At 11.5v, you will see about 180ma, and the resistors
will have to dissipate 1.62w, or 0.81 watts each,
which is very low.
2. At 14.5v, you will see about 240ma, and the resistors
will have to dissipate 2.88w, or 1.44 watts each.
Both of these numbers are very low and shouldnt cause any
problems at all. Worst case is 3.125 watts, which works
out to 1.6 watts per resistor, which is very safe.
The percent regulation in light output is about 14%, which
isnt too bad really.
If you go to a series regulator circuit, you will have to
provide a heat sink that can dissipate at least 3 watts.
Even though the efficiency is not good with either of these
methods, it's not really an issue unless you are planning
to run many strings of these LEDs, in which case you would
want to look into a step down switching regulator.
Good luck with your LED circuits,
Al
