brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
Here is my challenge:
There are currently available two 2x123 lights that will out throw all other 2x123 and 3x123 non-turbo lights of any manufacturer currently on the market or mentioned on CPF. These lights are the ASP Taclite and the TACM III.
This is a tall claim, and I invite any CPF colleague, dealer or manufacturer to attempt to disprove it. Anyone who does so to my satisfaction (I'll be reasonable!) will receive as a prize, a free unused Surefire clickie.
Anyone claiming that they have beaten my challenge must support that claim with at least one and preferably two Flashaholics as witnesses, along with a detailed description of the test conditions and methodology. Beam shots are excluded since it is very difficult to take reliable ones and if not done to exact criteria can be misleading. (I won't even speak of deceptive shots!)
A few points about contest criteria:
1) All tests must be conducted from a minimum distance of 125 feet from light to target; maximum distance is unlimited
2) All compared lights must have identical 123's (preferably Surefire), which are tested, voltage matched and have identical dates.
3) The Taclite must be the internal focus model using the teardrop shaped Triad lamp.
4) The Taclite must be adjusted to optimal "semi permanent" focus, a procedure which many owners fail to do properly, as it takes some time and effort.
5) In the unlikely event that a light other than the TACLITE and TACM III wins the contest, and if that light is one that I have previously tested, the winner will receive the SF clickie, but I will request that the light be lent to me to satisfy my curiosity as to how this result was possible. I will of course pay the two-way postage for this.
Brief description of TACM and TACLITE (Weight includes batteries)
TACM III..L: 4 5/8"...Wt:3.8oz...Bezel D:1 6/16"
ASP TACLITE: 5"...........5.4oz.……........1 6/16"
The TACM III has a Delrin body with interior metal sleeve, similar to the Surefire Nitrolon lights. It uses a proprietary integrated lamp/reflector, as does Surefire. Unlike Surefire it has a smooth reflector. There are two backswitch models, the regular version with a single front o-ring and the dive version with two, which is a true dive light.
Construction and fit are more than adequate, and the tail switch, while of a rather primitive design is perfectly functional.
The ASP TACLITE (Internal Focus Model) has an aluminum body and bezel with an excellent recessed tail clickie. It has a separate smooth surface reflector with a unique integrally mounted and focus adjustable lamp holder. The teardrop shaped TRIAD bipin lamp (mandatory for this contest), is firmly secured within the adjustable lamp holder by its pins and a rubber shock absorber that surrounds the lower end of the lamp. This is a very well built and elegant looking light with excellent ergonomics enhanced by an effective non-slip material covering most of the body
Both the Taclite and the TACM III have smooth reflectors which may partly account for their capabilities.
Although my description of the two lights seems to favor the TACLITE, both lights are remarkable performers and preference is a matter of personal choice. In fact, I currently EDC the TACM III because of its smaller size and uncommonly light weight.
Please note:
It is imperative to take all the time necessary to obtain optimal focus with the TACLITE. Once you achieve this it will remain set until you change it. It will not defocus inadvertently. This is the great advantage of the "Set and forget" feature.
Once in a great while, you may get a less than perfect TACM lamp module or TACLITE lamp and/or reflector. Unless you have more than one of each there would be no way to check this. This is one reason that I have included point #5 (above).
Finally, please remember this is a long throw contest. Beam aesthetics and 20' white target prettiness are irrelevant. These are powerful real world lights that can only reveal their true abilities in situations requiring intense light at medium to long distance. For example: This evening I walked past a low rise theater and flashed my TACM III at the top, approximately five floors above. The resulting spot was brilliant. The distance was far too short to test the light's capabilities. That is why I have set 75' as a minimum distance for this test.(EDIT) In fact, I am changing it to 125'.
Good luck to all and I'll be happy to answer any questions.
Brightnorm
Please note:
Brightnorm
