Chicago X
- Joined
- May 6, 2010
- Messages
- 439
I really like this torch. There's nothing wrong with it in stock form, but what couldn't be made better by upping the power four- to fivefold ?
The plan is to yank out the guts, replace with billet aluminum, then cram in a TRIPLE XM-L U2 setup with a 4-5A Turbo DRY driver. Can you say 3000 lumen out-the front ? Hehe...
Here's a seller pic as a reminder:
Link to TORCH here: http://www.cnqualitygoods.com/goods.php?id=1207
Link to HOST here: http://www.cnqualitygoods.com/goods.php?id=1208
http://www.cnqualitygoods.com/goods.php?id=1208Link to REVIEW here:
Here's a shot of the stock emitter, stock reflector.
Since I wanted the mass of the "pill" to be as much as possible, I worked from the bezel, rearward.
I cut a ring out of 6061 Aluminum, then cut a beveled edge to hold the optic:
Here's the optic and triple XM-L board from www.Cutter.au :
Optic in new retainer ring:
Here's what it looks like, test-fit in the bezel :
With LED board:
Coming up, the pill.
With LED board:
