I'm preparing for putting together a cable lighting system, where a bunch of MR16 fixtures hang from two bare wires suspended overhead. Traditionally, these systems use 12V AC with halogen bulbs, and there is a transformer that converts the 120V AC to 12 V AC.
Naturally, I'm planning on using LED bulbs instead of halogen. However, because LEDs draw much less current, many of the halogen 120V->12V transformers don't work properly. You need a different type of transformer, which is less common. However, 120V AC -> 12 V DC transformers are quite common.
As I look at different LED bulbs I've noticed that many say they work on both 12 V AC and 12 V DC. This leads me to wonder, since I am going to use exclusively LEDs, not halogens, does it even make sense to run 12 V AC? Would it make more sense to just do 12 V DC and then I would be able to use a common DC transformer to power it?
Does anyone know if the bulbs that operate on both 12 V AC and DC perform similarly to either? Is one better than the other for some reason? I know that internally it is being converted to DC anyway, so that's why I'm thinking that maybe DC makes sense, but I don't want to just assume that.
Also, if a bulb does not say either AC or DC, could I assume that they just aren't saying that, and it does in fact run fine on DC, or would there be some bulbs that could only run on AC?
I would like to make this somewhat future-proof if possible.
