Hi all. I'm looking to step up a bit from my old BD Spot headlamp (tilter broke). I will be taking this lamp on backpacking trips, so it needs to be reasonably light, secure and comfortable when wearing (balanced, no flopping around), and rugged. I'm tired of replacing headlamps every year or two! Budget is around $100.
I've been looking at Zebralight headlamps, the Spark SD52 or ST5, and the SureFire Minimus (though this seriously pushes the budget envelope). Lumens-wise, it seems any one of these would have sufficient output for a dark night in the mountains. Throw vs. flood is something I'm flexible on--it seems to me a good compromise between the two would be best (as I will be going on these trips with my wife, I'm not planning to carry two lamps).
Here are some thoughts I've had from my research on the internet:
Thanks!
- I love Zebralight flashlights, but I'm not sure about the headlamps. With the light on one side of the assembly it seems like it would always feel lopsided, and I worry that would really bug me. Plus I hear there have been reliability problems.
- Similar thought on the Spark ST5. It seems to stick way out, so I worry all the weight will make it flop around worse than my BD spot with out a tilter.
- The Spark SD52 seems like a good choice. My (nitpicking) concerns here are bulk and weight (full oz more than the minimus) as well as the flood beam. It has a ton of lumens, but it have any throw at all? I've heard the strap is not as comfortable as say the Minimus.
- The Minimus seems like probably the fest fit for what I want, but is it worth the extra cost over the SD52? And how about the 123A battery? I've only ever used AAs, so no experience with this. Is it an advantage? Disadvantage?
Thanks!
