moldyoldy
What do you do with your NiMH batteries/cells when your smart charger informs you that the cells have reached full charge? Assume that you have no other cells to charge.
Do you remove the cells from the charger and the charger from AC power? Do you leave the cells in the charger and still connected to AC power? Do you remove the charger from AC power, but still leave the cells in the charger?
Some chargers cut off the current totally. Some chargers switch to a trickle charge current. If removed from AC power, some chargers draw current from any cell still in the charger - meaning that the cell is being discharged.
Some data points: The LaCrosse BC700/900 switch to a trickle current at some percentage of the charge current. The Maha C9000 uses a trickle current. The Sony BCGxxx cuts off the current totally. The Titanium TG2800 switches to a trickle current if still plugged in, but begins discharging the cells at about 2ma if AC power is pulled.
Edit: Furthermore, if in the course of many charge/discharge cycles with multiple cell insertions/removals, the smart charger may become "confused" and give you unexpected responses. Before disposing of any product, remove AC power and any cells from the charger and leave the charger sit for a few hours, maybe even overnight. Amazing what that fixes. IOW, this is probably the price of using CMOS chips, or maybe poor/fast programming that became confused. ie: the TG2800.can indicate a bad battery on one channel even if there is no cell in that slot, yet nothing is wrong after removing AC power for several hours.
