moldyoldy
If you are attempting to save travel space as I am, here are some AA/AAA charger options in order of size from smallest to largest:
The Sanyo USB charger NC-MDU01 is a smart charger for 1 or 2 AA _or_ AAA cells without a discharge function. It is intended to be plugged in to a USB port on a laptop. Remember to turn on the sleep-charge function of the USB port if you want to charge while the laptop is off. The cell(s) become noticeably warm at the end of the charge cycle as expected. This charger can charge either AA or AAA cells via a flip-up bar, but not both sizes simultaneously. The single blue charge LED blinks slowly during charging and steady when the charge cycle has completed for both cells. It will reject a "bad cell" by fast blinking. The LED is physically hidden behind the front case shell, but is very bright in use. I placed a couple layers of dark blue tape over that area. The instructions state that there is a high-temp protection function to stop charging if necessary. My experience with this charger is a few months.
The Sanyo AC-based "Compact Charger" NC-MDR02NU is a smart charger for 1 or 2 AA/AAA cells without a discharge function. The cell(s) become noticeably warm at the end of the charge cycle, as expected. This Sanyo charger can charge an AA and an AAA cell simultaneously. The single red charge LED is on during charging and shuts off when both cells have completed their charge. The instructions state that there is a high-temp protection function to stop charging if necessary. It uses a US-style flip-out plug to connect to 100-240VAC. My experience with this charger is less than a month.
The Sony BCG-HRE is a smart charger for 1-4 AA/AAA cells in any combination in any slot. There is an LED for each slot. The LED will be on steady when that slot is charging. It will reject a "bad cell" by blinking the LED for that slot. The LED turns off when charging in that slot is complete. A discharge/charge function is available. A single buttom will start the discharge for all slots, however all slots have to reach the set discharge voltage before charging is initiated on all slots. It uses a US-style flip-out plug to connect to 100-240VAC. I have more than a dozen of these chargers in the old (with LCD readout) or new version (LED only) in use in my extended family and acquaintances in the US & Germany with no reported problems.
The Titanium TG2800 is a smart charger for 1-4 AA/AAA cells in any combination in any slot. There is a 4 segment LCD readout for each slot. It will reject a "bad cell" by blinking for that slot. A discharge/charge function is available. The discharge starts with a single button, but initiates charging automatically for each individual slot when the set discharge voltage has been reached. It uses a US-style flip-out plug to connect to 100-240VAC. My experience with this charger is less than a few months. This charger was reviewed by Silverfox - look in the Charger Comparison in the sticky compilation by Unforgiven at the top of the forum.
The next size up would probably be the LaCrosse BC-700 which offers more functions, including an evaluation of mah capacity. I had no problems with my 2 copies. However it is getting too large for my travel style.
