Foxfury,
Will you help me understand why your new series is so expensive? Besides the fact that it's a device being used by emergency services, why does it cost $200 for a 600 lumen light for only 2 hours of light. And after the 2 hours does it still operate on low?
Thanks.
-Alex
Hi Alex.
Fair question. These lights were designed specifically for firefighters to cut through smoke better than other firefighter lights on the market. We used premium materials including a brighter LED, deeper reflector and thicker housing than other right angle flashlights on the market. The result is a more durable light that throws farther and cuts through smoke better.
There are 2 Breakthrough models, the 200 torch lumen BT2 (MSRP $125.99) and 600 torch lumen BT3 (MSRP $199.99). The BT2 has a 2 degree beam and is better at cutting through smoke. The BT3 has a 3 degree beam and provides a larger hotspot.
The Breakthroughs cost more than other right angle lights and less than hand-held box lights. The Breakthroughs do a better job at cutting through smoke than both right angle lights and box lights used in the fire service....this was verified in a test (using a light meter) that we'll add to our blog in the next week or so.
I'll get back to you regarding your battery life question.
