The new Solarforce M3 essentially uses a slightly different P60 style pill and in a fit of pique today, I thought I'd see if a regular P60 dropin pill would fit in and work. Well, it does.
It takes about one minute to unscrew the stainless bezel, pop the lens and O rings out and drop the reflector and pill assembly out. From there the pill with XML-U2 unscrews and you can screw a regular P60 pill into the M3's reflector.
I had a couple of Solarforce dropins handy so just used those.
Here is a P60 pill in the M3 reflector.
The M3's pill uses a pill that's about 5mm deeper immediately behind the reflector - that slack is simply taken up by springs so contact isn't lost. What I did was drop a P60 outer spring into the host, then screw the M3 in on top. I used a regular Solarforce L2 with a single Trustfire 18650.
Here's an XP-G R5.
And an XR-E.
Now, the regular XM-L M3 with a single Trustfire 18650, on high at about 5 feet.
A single mode low volt Solarforce XR-E. It's a bit tighter than in a regular P60 with SMO and there's a spot within the hotspot if you know what I mean.
A three mode low volt Solarforce XP-G R5 on high. This is looking pretty good and is clearly more suited to the M3's reflector than the XR-E is.
A single mode RED XR-E was a spotty mess so I didn't bother with a beamshot.
My next thought is this - how is this light going to go with a hard driven XP-G G2 in it?
Or an aspheric setup of some sort?
Certainly an easy mod and I'll be checking it out when darkness falls.
Here's an XP-G R5.
And an XR-E.
