Duster1671
- Joined
- Oct 16, 2017
- Messages
- 244
I've been messing around with a custom build using a Lumens Factory KL4 head and H17Fx driver. I've built this up with an XP-L HI and a 219b (w/max output programmed down) and I'm having a nagging problem with the brass pill and aluminum reflector coming unscrewed from one another when the head heats up.
The Lumens Factory head consists of a brass pill with male threads that screws into the back side of the aluminum reflector. This assembly then drops into the KL4 head and is retained with the lens, o-ring, and bezel ring. When I run the light on turbo for a minute and then remove the head from the body, there is invariably a rattling sound when I shake the head. Disassembly reveals that the brass pill and aluminum reflector are no longer screwed tightly together. These threads being tight is what puts pressure on the MCPCB for a good thermal connection, and in one case I cooked an LED when the reflector loosened up.
I'm guessing this has to do with differences in thermal expansion between brass and aluminum, but I don't know for sure. What would be the best way to keep this from happening? Ideas so far...
1. Loc-tite - I could use loc-tite between the reflector and pill, but I'm not sure if 242 (blue) would be good enough considering the heat
2. Silicone - another thought is silicone RTV on the threads. Maybe better under heat, but also not sure about this...
3. Staking - perhaps I could screw the reflector and pill together and then stake them by hitting across the seam with a cold chisel. Again, not sure if this will work and how difficult it would be to get the components apart in the future if needed.
Any ideas or suggestions would be appreciated!
