nailbender
PART 11 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 10 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul - P7 , P4
Cree - XML2 , XPG, XP-E, MC-E, XRE , UV, are available here many in warm , neutral or cool white
Osram - Platinum Dragon IR/ Hyper-red
Luminus - SST -50, SST -90
These modules will fit most flashlights that accepts a standard P60/D26 Style module. They will fit Surefire C and P style hosts and all Solarforce hosts that take P60 modules. They also fit a variety of other manufacturers such as trustfire , ultrafire to name a couple
THESE DO NOT FIT OLD STYLE G2 HOSTS ( very old ) they will fit G2L's
_____________________________________________________________________________
Here are a couple of pictures of reflectors used. These are designed for XPG/ XPG-2 and such
Textured
Smooth
The XML reflectors are basically the same just with a larger center hole.
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibility that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may need to have the spring cut down to allow the head to close or a whole spring may be needed to keep the module from rattling. They also fit most Solarforce or any P60 style host
Please state if using in a FM Cooly , 2P maglite and such.
Most LED's are carried in Cool White, Neutral White, or Warm white when possible. They will be listed if in stock if not listed probably not in stock.
Battery configs listed are for any battery that falls into the range listed. Yes 2XCR123 will work in a 6 volt max config.
Potting is the filling of electronics cavity with thermal epoxy for heat management and shock protection. Copper tape is included with potting and both are included at no charge unless specified by member that they do not want this option.
ALL MODULES ARE LEAD FREE, ALL SOLDER USED IS LEAD FREE
WE NOW ARE MOUNTING ALL XPG2, XML2, NICHIA EMITTERS ON ALL COPPER DIRECT BOND SINKPADS
EMITTERS CARRIED
__________________________________________________ _______________________
CREE LEDS http://www.cree.com/products/xlamp.asp binning and tint information (GREAT RESOURCE) Look under documentation on specific type emitter
Cree XM-L2 $40
U2 flux 6500k tint
T6 flux 5000k tint
T5 flux 4500k tint
T4 flux 4000k 5B4 tint
S6 flux 3000k tint 90+ CRI
Driver choices are below.
Direct drive
1 Level only (potting and tape included this model only) works well in the 26650 Cooly's by Five Mega. Not made for continuous run.
__________________________________________________ ______________________________________
1 level 2.2 amps 3.6-16 volts best for use with Multiple cells.
Available levels with memory (2.8-6 volts only) 3amp stock setting all regulated
1 level - high Regulated
2 Low / High
3 level - Low / Med / High Regulated (5%- 30%-100%)
6 volt Drivers are 3 amps stock
Either Smooth OR Op reflectors available (extra reflectors on website.)
The new XPG-2 modules are located in this thread HERE
Cree XP-G -$35 *mixture of throw and flood*
2.8-6 (levels are 100% / 40% / 5% )
5 level low / med / high/ SOS / Strobe with memory available in 1.4 amp
4 level starlight / low / med / high 1.5 amps
3 level low / med / high 2.8-6 volts with memory available in 1.4 amp
1 level 2.8-6 volts
1 Level 4-14 volts / 1.5 amp
Flux Bins and tints that are available for XPG
Q23000K 7A3 (90 minimum CRI) NEW
Q4 2900k 8A4 tint
R4 4000k 5B3 tint /5B2
R4 5000k 3C tint
R5 5500k - 2T tints (Cool White comparable to WH tint)
S2 6300k - 1T tints (coolwhite comparable to WF tint)
DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 amp 2.8-6 volts max *Floody* (levels available are same as XML) some center clutter is visible in beam
DBS MODULES AVAILABLE ON REQUEST for most emitters / brass pill only no reflector/ same price as regular modules, potting is included on these also.
TWO NEW NICHIA 219B
Nichia CRI92 NVSL219B- R85 B220 4500k 90 CRI neutral ($35)
Nichia NVSL219B 90 CRI 5015K neutral ($35)
Driver Levels the same as the XPG's above
Cree XRE - XPE -$30 -
1.5 amp with memory
2.8 - 6 volts 3 level regulated Low/ med / high
2.8-6 volts 5 levels regulated - high / med / low / SOS/ strobe
2.8-6 volts 4 level regulated starlight / low / med / high
3.6 -16V regulated @ 1.4 amps - 1 levels
XPE Good Throw
R2 or R3 available coolwhite / (Q3 5B)neutral /warm tints
XPE Green , real Red, Amber /Blue
XRE (Good Throw )
R2 flux WF tint
Q45B neutral
8E7 warm white
Green/ blue/ royale blue colors
Smooth OR OP reflectors are available
Optics are for XRE emitters only / Cool white , neutral white and warm whites.
8degree/ 60 degree.
$37 for module and 1 optic $40 with 2 optics
Cree MCE $ 50 - GOOD FLOOD
1 - 3 or 5 level regulated 2.8 - 6 volts
Cool - M bin WD, WG
Cool - Nbin no tint supplied but pure white
Neutral - Kbin 5B tint
Warm bins JE5, JE6, KA3
LUMINUS SST SERIES LEDS
Luminus SST-50 - $55 -
2.8 -6volts only *good throw with adequate spill*
direct drive
1 Level direct drive
Regulated with memory offered with same amperages as XML's listed above
1 level
3 level -- Low - Med - high
3 level -- low- high- strobe
Flux Bins are
6500K Cool White (W65S-GJ102-WJ-G4 )
5700k (w57S-GJ201-WJ-H4 )
4500k (w45S-GJ400-WJ-P3 )
Luminus SST -90 -$70 -
2.8 -6 volts only *Floody*
1 Levels direct drive or regulated drivers with memory with the same amperage drivers used with XML's above and same levels
6500 (W65S-WN-G3 )
5700k (W57S-WN-H4)
Green - Red- Blue Colered SST90's also available
OSRAM IR LEDS
Osram Oslon Black IR $40 (850 940nm)-2.8v- 6 volts /1 level / 3 level - 2.8-6 volts
Generic Quad Die 10watt IR great for night pictures
I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white and high CRI models.
Now as to levels in drivers , most of the time the levels are fixed and can't be changed. As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
Please specify what host and batts you are using when inquiring about a module or led. Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first. These are not try and buy ask if you don't understand!
Now that said the search button for this forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted please check the forum's search box as it is invaluable.
When ordering please post your order in this thread plus put details in Paypal notes of what emitter and tint ordered/ include choice of reflector / # of levels / check to see if shipping address is visible . Also please list CPF Nickname in paypal notes.
Shipping is 3 working days Although next day is not unusual Shipping confirmations are sent from Stamps.com when mailed
Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
If you want it mailed to an alternate address from the paypal address please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
MY Paypal info in biography or PM for it / I do not send confirmations that I received your paypal if it is properly addressed then I WILL receive it, you should be receiving a receipt from paypal when sent if configured properly
1st class shipping is included CONUS
Domestic Priority is $5 for up to 4 modules
International shipping is $12 for 1st class Int up to 3 modules , Priority Mail Int. is $23.95 up to 8 modules , express mail and more than 8 modules quoted.
Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
New offerings will be listed below as they become available under news.
XPG-2 modules can be found here
90 CRI XML modules can be found here
D36 for M STYLE and M to C lights are (HERE)
_____________________________________________________________________________________
IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
Here on BST Five Mega hosts are some of my favorites and here is the new coolys
On marketplace get Fivemega 18mm Bodies in Multiple Sizes from Wonderlite and Jason will take good care of you.
For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
SSC Seoul - P7 , P4
Textured
Smooth
EMITTERS CARRIED
Cree XM-L2 $40
U2 flux 6500k tint
T6 flux 5000k tint
T5 flux 4500k tint
Direct drive
2 Low / High
1 level 2.8-6 volts
Q4 2900k 8A4 tint
R4 5000k 3C tint
TWO NEW NICHIA 219B
1.5 amp with memory
XPE Good Throw
XRE (Good Throw )
R2 flux WF tint
Q45B neutral
8E7 warm white
8degree/ 60 degree.
Cool - M bin WD, WG
direct drive
1 level
Flux Bins are
6500 (W65S-WN-G3 )
5700k (W57S-WN-H4)
OSRAM IR LEDS
