CuriousOne
- Joined
- Oct 14, 2012
- Messages
- 813
Hello.
I have 7 pieces of SFH 4233 IR leds (500mW radiated power, 940nM). I want to fit them with a reflector, to get tight beam for night vision illumination. The problems is, that most commercially available reflectors, which claim compatibility with these leds, actually can't produce focused beam with them, only wide spot. I've tried to use collimator lens, but seems that plastic adsorbs IR light strongly - light was even weaker than without lens!
At the same time, I have Streamlight Super Tac IR flashlight, which uses same type of led, and produces very tight, focused beam. The problem is in price - this flashlight costs $80. I've examined it's reflector and found out that it is quite unusual shape, it is almost 3 times longer than it's diameter. So I assume, for IR, we need different reflector shape.
So anyone experimented with tight beam reflector for these lens?
