Nitecore Chameleon CU6 (XP-G2 + UV + RGB)
y260
Hawaii, USA
So I was browsing over Nitecore's Facebook page and saw this:
Looks like an interesting tool. Will probably appeal to hunters, detectives, etc.
viperxp
Israel
That's clever marketing. Creating products that just don't have any real competition...
jonwkng
Singapore
Nice! I'm sure it will appeal to many flashaholics too! :D The only other dual emitter commercial flashlight (for those of us not using UV emitter drop-ins) that has good 365nm spectrum output would be the Streamlight Nightcom UV.
shelm
I'll do the CU3 when it becomes available.
i prefer CR123A style EDC format and french fries.
AN/MPQ-53
The Nitecore Chameleon's in 5 versions:
CB6 - White and Blue
CG6 - White and Green
CR6 - White and Red
CU6 - White and UV
CI6 - White and infared
White 400 lumens (ANSI)
Color 400 Lumens
1 x 18650
Separate switches for white and color.
5 brightness levels for white, 3 for color.
In addition, two small RGB LED's (like SRT series).
UCL
143mm x 40 mm
139 grams
lampeDépêche
I don't get this: 3000mw of UV? 3watts of UV??
UV is fun--I have a couple of small lights for looking at currency, rocks that glow, etc.
But 3watts worth? What's the idea--that you can track your wounded deer and cook it at the same time?
This could really be a health hazard--people who are not used to taking precautions could get serious sun-burns or eye-damage.
Or am I just totally misunderstanding something? Doesn't that seem like a ridiculously powerful UV source?
I know 3watts is not much for a visible light. And if it were IR, I could see why someone would want to be able to illuminate things at a distance for use with NVG. But with UV--what's the idea?
Sherbona
I have a PowerTac Chameleon (very fun light if you like color LED).
PowerTac Chameleon
multiple Cree XP-E (numbers/spec from the powertac site):
- Red: Cree XP-E 625nm, High/Strobe 110 lumens, Low 40 lumens
- Green: Cree XP-E 530 nm, High/Strobe 150 lumens, Low 50 lumens
- Blue: Cree XP-E Royal Blue led 460 nm, flux on High 765 mW, flux on low 260 mW
- UV: 4x led, 380 nm @ 15 mW
- Mixed Red/Green/Blue: White-ish Light, 30/60/120 lumens, also Strobe
- Mixed Red/Blue: "Magenta-ish"*, 80 lumens
- Mixed Red/Green: "yellow-ish"* 135 lumens
- Mixed Green/Blue: "Cyan-ish"*, 120 lumens
*my perception
Misc:
- Magnetic ring switches between light combinations
- Battery: 2 x CR123A or 1 x 18650 **
- Dimensions: ◦ Length: 144mm
- Bezel Diameter: 58mm
- Body Diameter: 25.4mm
- Tail Cap Diameter: 34mm
- Weight: 253g (Without Batteries)
** For me, keeppower 18650 doesn't fit (due to diameter), but Eagletac 18650 does.
Comparing these two Chameleon's (basing on specs in AN/MPQ-53's post)...
- The powertac is better for color combinations.
- The nitecore has a dedicated white - with the powertac one can only get a white-ish effect with RGB.
- The nitecore has more powerful color led, not sure about the rgb leds.
- The nitecore looks like it will be an easier carry (smaller bezel/head diameter).
I'm pretty excited by this. I see myself getting a CR6 (White/Red) to serve as a backup light for my long bicycle night rides - white to backup front light, red to back up my rear light). If price is reasonable I will probably get the others too for fun.
lampeDépêche
Notice that the Powertac's UV power is 15mw.
Now that strikes me as a sane amount of UV for currency authentication etc.
Could the 3000mw figure be a typo? Or maybe it describes only the white light?
lampeDépêche
Wertzius,
Thanks for that link. That modder, Vinz, is doing *beautiful* work. Stunning quality of machining and design!
He says that it is for "forensic" work, but I am still puzzled: why does anyone want such a bright, intense, UV light? Especially with an aspheric--is he planning to spot blood-droplets at 200 meters????
In any case--thank you for the link.
wjv
I was watching Ghost Hunters International and they stated that Ghosts don't like UV light. . .
So you can use it for self defense against Ghosts! :D
JulianP
Sydney
3000mW of UV - You can sun-tan yourself, light up a huge phospholuminescent cave, cure some UV-sensitive plastics, be the Disco-King...the possibilities are limitless.
