Greetings, a friend asked me about a warm white flashlight like 'the one I have'.
It's an oldschool 4Sevens Quark Tactical 2AA Warm White running on 14500 in the AA body.
What a great flashlight ! Especially for hiking in the dark, I have nothing comparable.
It's programable, compact, very bright on 14500, the warm white LED illuminates natural things perfectly (and it was a wise decision to buy the extra switch, clip, body, so the light can be modified to all needs).With the other switch it can tailstand, with this deep pocket clip it can easily be attached to a hood/sleeve or baseball cap etc..You can even swap the switch and the head to get the clip in the other direction. The UI is also a winner for me, I can program it to moonlight/medium output for using inside the house. Or if I want to it's max output/strobe with momentary activation due to this switch.
A few years later I'm still speechless for it's versatility and it's still working flawless - BIG thumbs up for 4Sevens !
But if I remember right the warm white was a limited run and I can't find anything like this.
Could you recommend me a few lights matching most of the points below ?But it must be warm white since he already owns some cool white lights !I'm still very happy with the few lights I own, so I didn't follow the CPF regular - shame on me, so I hope you could help me pick one !
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
____Up to $50.
If it's really THE flashlight, it can cost more.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
Pocket/AA size
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
Will mainly use eneloops, but the option to use 14500 for higher output is also nice.
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X_SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
If possible, I like that option.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
It should have both, flood and throw.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a tail mounted switch (found on the majority of today's high end lights).
Not really that important.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
Multiple output is important, the other options just would be nice.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
It should be waterproof but it's not for diving.
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
Depends on situation.
I'm looking for a warm white light, to illuminate natural things.
____Up to $50.
3) Format:
4) Size:
Pocket/AA size
6) Manufacturer:
