Some of my uses are for ecig VV mods,so use some IMR cells ,but most i dont need and good standard cells like LG/sanyo/pany are fine as dont push my equipment like others do ...........
The highest drain light i have iirc is the x3vn and with an IMR 26650 kinoko of vinhs, testing it measured 9.6A so i use a kinoko cell in mine too.
Other lights like my tn35vn which is "only" 3500lm i would be ok to use pany cells,BUT i cant fit them due to the carrier mods.I use KeepPower IMR 2100mah 30A ,so another benefit on some carriers/lights that may prefer a shorter cell for food.Some cells are 70mm,some a little over and can be tight or even damage...........
I tried IMR KPs and Pany standard and to my eye could not notice a difference,so over 2100mah or 3100mah( for example) a longer run time, but the pany cells may not perform as well for as long even though run time is more on the pany cells.........
mm15vn which is 6.5A per cell, would happily run on pany PFs 10A cells,but decided on more KeepPowers at time for no real reason
now i have the sony vtc5 30A at 2600mah so a little longer run time.
My tk75vn at around 4400lm i use pany protected cells and work fine for 4.5A ,might test on some IMR and see if i can see any difference!
For smaller lights,v11r and d25cvn/d25a,
i use these cells or KeepPowers
Which brings me on to another thought,depending on use,you may require 4hrs+ of medium power(just an example here) and as IMR tend to be lower mah,a higher capacity cell would be more advantageous for longer run times.
For the use of Tex ,any good brand cells will be fine,no need for IMR imo,you may see a difference in output(depends on light etc) and then you would have to consider an extra X amount of lumens Vs less run time for your use/s.
I think the PFs that matt mentioned offer a good all round choice at 10A and 2900mah for 18650 cells,good value for money too:thumbsup:
so i will be getting some PFs at a later date
