So this journey started about a year and a half ago viewing this forum and wanting to have a modified flashlight since I'm a tactical flashlight type guy. I had an extra 3 or 4 D cell maglite laying around from a supressor and AOW project I was working on, and I thought it would be nice to have brighter flashlight than my Fenix tk15 that I still run when at work.
Anyways , this is the head that they recommended to install into the maglight body that would be the most minimal of modifications and most of that had to do with the switch assembly, which btw I cannot find an Allen key the correct size to release it from the body. http://www.dx.com/p/6-cree-q5-wb-5-...odule-52-7mm-42mm-8-4v-max-65153#.U7T_OmK9KSM
My problem is that as it says it is drop in, it doesn't drop in exactly as I can't get the plastic glass ring to thread to the bulbous portion of the light without removing the plastic glass completely.
And the second problem is that I'm not sure if it's working or not electric wise as I removed the glass and got the ring on slightly and then tried installing it / inserting it into the cavity where the former basic led conversion bulb went and was working. It was one of those $20 Home Depot pop in led bulbs to get better light and life out of the maglight, so I know that the light has power from the D cells and the switch works, but when I tried to get the new conversion head to power up, nothing happened at all.
Is it that I have a bad connection or need to modify power connection, or do I need to ditch the d cell batteries for ones like I have in my tk15 , aka cr123 / 18650 , and if so what is my best economical option in the long run just in case I want to get into more flashlights and higher lumen flashlights. This is my first venture into the custom flashlight realm and would like to make it a positive one.
Thanks.
Thanks.
