snigelkott
- Joined
- Jan 17, 2015
- Messages
- 9
Hi guys!
I'm looking for a flashlight that use 1 AA with the possibility to run on 2 AA.
Going to use it for EDC and some camping, that's also why I want it to run on AAs I want to be sure to always have access to fresh batteries if my eneloops run out.
I have checked out the S15 and the Neutron 2A v2 but I would still like to run it buy people here.
This will be mail-order or Online (world wide shipping).
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $60.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
TINY - Every day carry (2-4 inches).
SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
I want to navigate a dark room or read a map (1-10 lumens).
I want an indoor "blackout" light (15-50 lumens)
I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
__x__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
Less than 1 yard/meter (reading, other close work)
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
30-50 yards/meters (I have a big backyard)
50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
90-120 minutes (Runtime is moderately important, but still not critical)
Very Important (Camping, Backpacking, Car Glove-box).
I want a forward clicky (Helpful for momentary activation and signaling).
I want a reverse clicky (For use with multi-mode/level lights).
I want a body mounted switch (near the head, like on a Maglite).
I want a tail mounted switch (found on the majority of today's high end lights)..
I don't know.
I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
IPX7 (Waterproof to 1 meter/30min)
IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
Other, pocket and backpack
Up to $60.
3) Format:
4) Size:
6) Manufacturer:
I don't know.
