drillbitz11
So what started as a simple led swap ended In a very expensive paperweight. I only had 16mm boards so I used my dremel to bring it down to 12mm to fit the SWM and I must have damaged the trace or I shorted on the body somehow. Anyway The driver smells like burnt rubber and I was hoping someone knew the best avenue to take to fix it. I'd be glad to just buy a new driver but is that possible? If anyone has had dealings with Sunwayman, I love to hear the steps you had to take. Thanks
