Eneloops
- Joined
- Mar 19, 2012
- Messages
- 171
My worst examples are from a Fenix HL-55 and a ZebraLight H600 headlamps, but I imagine the same issues are found in handheld torches as well. I'll get used to the UI on the Fenix, where I have to hold the button down for 2 seconds to turn it off, then intuitively do that to my ZebraLight, resulting in it staying on (low) without me knowing it, all day. I realize battery drain is minimal, but it's more annoying than anything, and utilizes too much of my minimal mental capacity to think about.
Then I'll get used to the ZL, and when I don the Fenix, I end up constantly cycling through all the modes trying to turn it off. It's become enough of an annoyance that I'm thinking about ditching one of 'em, to free up my consciousness a little bit.
Does the configuration of the user interface come into play when you consider buying a light? Is it a deal-breaker for anyone else, if it's too different from what you're used to?
On all my lights where you change modes with a quick depress of the button, I end up cycling through the modes almost every time I use it. Counting the steps, to figure out where I am. I prefer the ability to set the brightness before turning it on, and it staying there no matter what I do with the button, until I change it via a control ring, or maybe a separate button or switch. My only lights that work like that are the Fenix E-11, E-21, SWM V10R/V11R, and my single-mode flashlights. I adhere to the K.I.S.S. rule when I can, as anything smarter boggles my mind.
:shrug:
:shrug:
