KeepingItLight
Of late, I have become focused on the importance of knowing how a flashlight that runs on Li-ion batteries behaves when the voltage gets low. Unfortunately, flashlight reviews do not always do a good job describing how a low-voltage condition is handled.
Over-discharge of Li-ion
Depending on its design, a flashlight might do one or more of the following when voltage gets low on a Li-ion battery:
1. Nothing. The flashlight continues running until the battery is exhausted. On a protected battery, this should trip the protection. When the battery is unprotected, this could run the battery well below its safe discharge limit.
2. Provide a signal of some kind. Often this is a flashing red or blue LED on the body of the flashlight. On other flashlights, the main beam blinks periodically. Besides giving a signal, the flashlight continues to operate normally. It is the user's responsibility to respond to the signal, otherwise the dangers described in number 1 above apply.
3. Force a step-down to a lower level. Zebralights, for instance, do this.
Unfortunately, a flashlight user may not respond to any of the situations described in numbers 1-3 above. He might, for instance, put down his flashlight, and forget that it is running. When that happens, the only thing standing between a flashlight user and an over-discharge is the protection circuit of a protected battery. If that circuit fails, or if the flashlight is running unprotected batteries, an over-discharge is likely.
That brings us to the final possibility.
4. Turn off the flashlight completely using a low-voltage cutoff circuit. This is the only sure way to prevent an over-discharge. Once again, most Zebralights take this approach. On the SC62, for instance, cutoff occurs at 2.7 volts. Prior to this, you get forced step-downs from hi to med, and from med to low.
A Request for Flashlight Reviewers
If you are a flashlight reviewer, I ask that you routinely include a section describing in detail what happens when the Li-ion battery in a flashlight is over-discharged. The treatment should be systematic. It should appear in the same place, and in the same form, in every review.
Start with a direct statement describing whether there is a low-voltage cutoff. This simple yes-no statement should be as routine as the yes-no we usually get regarding tail-standing. If possible, provide the voltage at which cutoff occurs. From there, detail which of the other features described above are present. The several possibilities were numbered 1a, 1b, 2, 3a, and 3b. If possible, a review should discriminate between these five behaviors.
With this information, flashlight buyers will have a better understanding of what they need to do to make sure an over-discharge never happens in one of their lights.
1a. Doing nothing is perhaps less dangerous on a poorly regulated flashlight than on one that is well regulated. If a flashlight is getting dimmer as the voltage falls, the operator should notice.
1b. On a flashlight with a well-regulated boost driver, however, doing nothing could be a problem. The operator might not see any dimming until it is too late to prevent an over-discharge.
3a. On a well-regulated flashlight like the Zebralight, a hard step-down to a lower level is quite jarring. From personal experience, I know that an operator who is paying attention cannot fail to notice. The step-down will also give you extended runtime at the lower level.
3b. If, however, a flashlight has a slowly declining, direct-drive-like output, it is possible that a forced step-down would not be as jarring as it is in a Zebralight. Amid the general dimming, it might go unnoticed.
