PoachedEgg
- Joined
- Oct 30, 2015
- Messages
- 7
Hi this is my first post, Ive been lurking here now and again and I would be delighted if you guys could help.
At the moment im using a thrunite Ti3 (WHICH I LOVE) for my EDC and I have an old 2008/2009 led lenser police tech which is my main home torch.
I really like the led lenser its a solid as a rock and does the job great and has lasted a long time, the only problem with it is that the light will not stay at its max lumens and will decrease lumens along with the battery life.
I was really set on getting a thrunite tn12 2016 model it seems to fit all my needs and i can get it for £48 with a charger and battery, However after reading some threads on here about it potentially over heating after 10 mins of use and no auto dimming or power regulation on turbo im having 2nd thoughts.
The alternative is the Fenix PD35 TAC 2015 edition which seems to have auto dimming and better power management, over all better build quality and quality control then the tn12. However the fenix pd35 tac will auto dim after 5 mins on the highest setting to prevent damage, so the fenix will still get damage like the thrnite but the only difference is the fenix will go to a lower setting after 5min, but if the user was to go back on to turbo mode on the fenix wouldn't they be able to damage the torch anyway? the same way a user could damage the thrunite by keeping the turbo setting on for to long?
The fenix pd35 tac is also quite a bit more, amazon dont seem to have and everywhere else seem to stock at £59.99 apart from some Chinese site called gearbest.com which are selling it for £46 but im apprehensive getting from them because the Chinese are know to fake torches right?
Anyeay any advice i thank you for, I would be welcome to hear of any her brand torches that fit this criteria.
cheers guys.
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
Im in UK so £50-70, would be better if it came with a battery and charger
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I don't care - i would like the cheapest version
I want an all round, main torch, for use when theres powercuts, possible intruders, walking the dog and attaching to my bike posible
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
I would like both really, somthing that will work with the requirements I have, A good all rounder that has a decent beam and can light up a room or surrounding area
it will be my main torch, so it will have to bee good in close quarters as well as longer distances when out walking the odg or bike riding
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
i want it to last as long as posible so the longer the better
i like the fenix pd35 tactical's design, with the ability to go into stobe using the back buton, Overall i prefer the back clicky button option ,
a strobe function would be handy incase of home intruders, and at least 3 different power modes are needed, to suit each situation
14)Material/Finish/Coatin
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_
15) Water resistance
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
it wil be in house most of the time but could be in colder condition and i want a torch that can stand up to almost anyhting
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
cheers guys.
3) Format:
4) Size:
6) Manufacturer:
_
____Holster
