I have some 18650 2700mAh batteries that i need to get 24v 10amp out if it. Whatwould the best wiring to acheive this? 6s6p ?
Without knowing more about your cells (chemistry, brand, protection) and what you're trying to accomplish (what are you trying to power), it might be hard to answer your question.
Are you sure your car has a 24 volt electrical system? You normally see those only on heavy trucks and equipment.So i plan to use these to jump start my car. That will require 24v @ 10amps.
To be honest, without protection and balancing circuitry, that sounds like a recipe for disaster.
A car can start with a lipo 12v 8amp. It just needs it for a few seconds. So i was just trying to do that with Li-ion.
http://youtu.be/UBp8YGY5ouk
So from what i learn its all about discharge capability measured in C is what makes the difference and the 18650 batteries are not capable of.
For my knowledge what would be the c rating for these batteries? And for a 3s6p?
