Hello, I am an electrician building a children's hospital in Palo Alto. I'm stumped on a led set up for a 3ft strip light and was hoping I could get some suggestions on hooking the components up. These are the components involved:Color pro DMX wall switchPX24500 DMX decoder driverPOE Injector Phillips Multi-Protocol ConverterAnd all the required power supply's The way I see it should be hooked up is the color pro plugs into the Poe injector with cat 5 then back out of the injector into the Ethernet side of the MP Converter, then out the other side DMX to the DMX decoder/driver. And I should have light! No go! If I unplug say the cat 5 from the driver and plug it back in I can get the strip to light up red. But the color pro while lit up will not control the driver. I'm stumped. Any help would be appreciated!
