Hello everyone, I am looking to build full wire harnesses on both our vehicles. I want to use fuseblocks that uses a large gauge wire to distribute power to 8 relays. 2 hi, 2 low, 2 fog and 2 aux driving lamps respectively. Basically i dont want 8 dloops hanging off my batteries.
I am also looking for input in regards to relays (weatherproof required), wire and pigtails. In the past I have used hella weatherproof relays, and crappy wire with good results, but if theres better options I am all for it.
Power consumption will be high, with two Fyrlyt Nemesis in either auxiliary position, so i need the main cable to be large enough to support enough amperage for lows (H11/9012) Highs (9011's) and Fyrlyts running at the same time. Both vehicles keep the lows on with the highs from the factory.
So a total shopping list should look something like this
-Main Power Cable
-Distrubuition/Fuseblock for power
-High Quality Cable
-High Quality PigTails
-High Quality Relays (weatherproof)
Goals:
-Clean Installs
-Full Voltage to all forward Lighting
-Reliability
Any advice/input is appreciated.
-Colin
Hello
For what its worth, there are tons of solutions with automotive power distro boxes. Some really involved, some plug and play..
I spent the entire winter last year seaching out a solution. Depending on the manufacturer, it can be a cheap as $100 to upwards of 3 grand depending on what your trying to power. The jeep industry has jumped on this market segment like a hawk as most ppl have no clue how to safley wire in accessories, nevermind a relay or switches.
For plug and play type stuff you can check out
http://www.4x4spod.com (over priced imho)
http://www.switch-pros.com (solid state style, very small)
http://www.autorod.net (been around a while)
http://www.painlesswiring.com (TrailRocker, really clean Staten as are others above, all labeled and 8 relays)
Google Search -
Offroad Engineering - solid state
http://www.offroadengineering.com/product-multiplex-system.html
Cooper Bussmann RTMR (bussed relay/fuse options $100-$120 pre wired on ebay)
Cooper Bussmann RFMR (much bigger version of above, good solution for a entire car)
Littelfuse programmable fuse box
Littelfuse 6 relay waterproof fuse box( hard wired, i like better than RTMR)
Infinity box (all solid state programmable, daisy chain multiple)
AW Direct (towing catolog) has some variants
I could go on and on.. there really is alot of options out there, they are just buried in sites etc and dont automatically show up in search results as their model names dont usually contain your search terms.
Lastly, if your dont mind a all in one module, the Feniex Industries 4200 mini is a pretty cool programmable distro center, it just doesnt have big amp ratings, but for what you get its worth the 100 bucks to have your switches already wired and all you have to do is connect ground power and your outputs. There is also a 4200 thats bigger with alot more functions and a seperate switch pad, BT connectivity, a touchscreen rearveiw mirror switch pad, 17 10amp outputs, etc.. Tons of features..
http://www.feniex.com/4200-mini
http://www.feniex.com/s-4200
Whelen has a bigger amperage unit, kinda the same as the one 4200 mini, its a 9 switch plug and play unit. I find it kinda bulky and old looking but it is a industry workhorse. Its called the PCCS9R. Whelen also has a 8 position remote module panel with plug and play keypad called the PCCR8 or sometgi g along those lines. Just google it, it will come up.
http://www.evpp.com/switch-and-cont...ntrol-for-standard-switching-replaces-pccs9r/
http://www.strobesnmore.com/Whelens-All-New-8-Position-Key-Pad-with-Remote-Relay-Module.html
Another idea i came across was Drag Racing forums, these guys have been wiring up cars for as long as cars themselves.. There is a ton of options there with relay panels, however most of them are not waterproof as they run them inside the stripped down interiors.. Check out Yellowbullet
http://www.yellowbullet.com/forum/showthread.php?t=431340&page=15#/topics/431340?_k=czf7so
A guy called Nitrous Dave (google) has a $120 10position relay board that is fused unlike most ebay relay pcb's are. Power, Ground, Outputs and you of to the races..
Check out spaghetti Menders...but pricey though
Speedwire, again really pricey, but alot of output options.
ConcoursSpecialties - good eBay seller but for some reason has nothing in his store right now, i think they are updating his .com website.
Lastly, and trust me there are more, my brain just hurts..
Leashelectronics... This guy has some really trick looking stuff at very very reasonable prices. Use the full site, mobile freezes up.
http://www.leashelectronics.com/Pro8-Relay-Module-Pro8.htm
BANG FOR BUCK WITH NUMBER OF OUTPUTS, I'D PROBABLY GO WITH A RACE CAR SOLUTION.
