HKJ
[size=+3]Charger Xtar MC4 update[/size]
[size=+1]Review of MC4, read this first[/size]
This is a fairly small 4 slot charger from Xtar with usb power input. It can only charge LiIon batteries.
This review will only be an update, not a full review.
[size=+2]Measurements[/size]
A normal charge curve, it looks the same as the first review.
With a 0.5ohm resistor in series (i.e. a weak power supply or a long cable) the charger over charged the batteries, the updated version do not over charger, in this case the charge voltage is a bit low (Within the allowed +/- 0.05V).
I tried one test more, this time with a 1ohm resistor, i.e. even worse cable and the charging was perfect.
The orginal test was with 4 cells in the charger and it also looks fine in that case.
[size=+2]Conclusion[/size]
This means I will give the charger a good rating.
[size=+2]Notes[/size]
The charger was supplied by a Xtar for review.
Here is an explanation on how I did the above charge curves: How do I test a charger
