Capolini
Banned
K60vn-STATERA THROWER-XHP70.2 CW 6500K
MAX/LEVEL 5 RUN TIME TEST.
I am very impressed with how this manages heat.The first increment was for 10 minutes and the handle was barely warm!
In candle lamp's review he stated there is a step down after 2 minutes.That is correct as I noticed the slight drop of output on the ceiling. When that happened I dialed down quickly to level 5 and then back up to level 6 to see if it reset TURBO. I do not believe it did as I did not notice an increase in output.
It is CONFIRMED when I turned the light OFF/ON again, it resets back to TURBO.My test is a combination of MAX and level 5 output.
NUMBERS BELOW.
I was happy to see that my 30Q FT did NOT rattle when I shook the light. That was NOT the case with my TN42vn,,hence BT 30Q'S!
I can not wait to use this light tonight. I am sure I am going to like it.
PLEASE NOTE:
1.My 30Q FT's were received on 10.24.2017. They have been in storage most of the time and ONLY have 12 cycles on them.
2. The test was a COMBINATION of Level 5 and turbo. I found by turning the light OFF/ON again, that it reset it to TURBO.
16 minutes were TURBO and 19 minutes were Level 5.
The Numbers:
PHOTOS
Comparison Line up
My custom design. CAPO /COCHISE COMBO w/ v54 in the middle!- Vinh's Craftsmanship. Tight Quarters.
Here is a picture of Cochise at age 13. Malmute/GSD[German Shepard Dog] mix
Beam shots coming soon.
NUMBERS BELOW.
PLEASE NOTE:
The Numbers:
PHOTOS
Comparison Line up
