HKJ
[size=+3]Charger Leise NiMH 2 slots LS-U2C[/size]
This is a fairly simple dual NiMH charger powered from USB.
It arrived in a cardboard box with brand name and not not much else on it.
The box contained the charger, a usb cable and a instruction sheet in Chinese.
The charger is usb powered with a micro usb input.
There is a led for each slot that will light up for the 9½ hour a charge takes.
The specifications are on the bottom of the charger.
The charger uses the classic two level construction for AA/AAA batteries.
[size=+2]Measurements[/size]
The battery is nearly charged fully in about 9½ hour with a fairly low charge current.
This cell is charged fully, again in 9½ hour.
The pro is far from fully charged, the charger again used 9½ hour.
Not much surprise, 9½ hour charging and the charger stops.
The AAA also gets 9½ hour at a lower current and is overcharged a bit.
The full eneloop gets 9½ hour, that is about 9 hours of overcharge.
With two batteries each battery gets the same current and the same 9½ hour.
M1: 40.5°C, M2: 40.5°C, HS1: 97.0°C
The charger use a linear regulation and need to burn some power, this means there is a rather hot location on it.
Being a very simple charger I could draw the current profile. There is no regulation.
The charger do not have any controller that need time to initialize, but starts immediately
[size=+2]Conclusion[/size]
The charger is a very small size, due to this is can be useful, but is is very slow and use a timer based termination. The low charge current means that damage to a battery is fairly limited and the charger can be used sometimes, but it is a bad idea to use this charger as the main charger for NiMH.
I will rate it usable.
[size=+3]Notes[/size]
Here is an explanation on how I did the above charge curves: How do I test a charger
- Power consumption from usb when idle with no batteries is 0.4mA
- The charge current will depend on battery voltage, see voltage sweep curve below.
