Burnt_Retinas
I tinkered with an LT3436 and thought it'd be good for a decent LSV driven from 1 X Li-Ion. I had to sacrifice my last X3T I got as a spare for my MR-X from Hotbeam for this one so it hurt a bit.
The parts:
Homebrew LT3436 voltage regulated boost circuit.
PM6 host.
McModule.
1 X 17650 Li-Ion.
Clickie.
Mineral glass lens.
The results:
This chip is capable of wicked currents into an LV. Using a bench power supply set to the nominal voltage of a Li-Ion – 3.6V, I could hammer the X3T to approx 1.6A. This was found out by an accidental slip while paralleling resistors to tweak the current where the IC defaulted to it's own internal current limiting. The current drawn from the supply was 4A. Obviously way too much for decent runtime or even the health of the LED, battery and circuitry, so down it went. I settled on 900mA output current. Why? – why not? It gave reasonable current drain from the battery, reasonable runtime and great light output. I just had to have more than 750mA though.
The numbers for 900mA/3.6V input were:
Input = 3.6V, 2.05A
Output = 6.62V, 900mA
Efficiency therefore 80+%. About what's expected.
It is worth noting that the LSV did exhibit a rather large current increase with temperature. One would expect some with a voltage regulated circuit however. With the LS only mounted to the McModule, not the PM6, it got hot quick. Using my calibrated finger tip I guestimated the temp to be about 50c on the McModule at which point the current was 1A. This was still OK by me as it'll help compensate for the LS's reduced output with temp characteristics.
While I was at it, I thought I'd try one of these with a TWOK mod in the same host. Same parts as above, but with an LIII TWOK driven at 1.2A, but that's another story – btw works so great I don't know if I'll go a slightly more efficient route for a while using the TPS61030 as per others tinkering's. An extra 10% is like 40 minutes vs. 44 minutes. If I had the parts, then I would do the more efficient route for the LIII (not an option with the TPS61030 to drive an LSV).
My opinion of LVX3T at 900mA/PM6 vs.LIIITWOK at 1.2A/PM6? Get 'em both! The LIII TWOK throws a tad further and appears whiter, but there's some darkness between the sidespill at the feet and the hotspot. The X3T just gives out an almighty blast of light from the feet to way over 50m. They each have there uses. For a pocket-able flashlight either are awesome!
Yep, there's more we can do with these Luxeons. Smaller, brighter, regulated!
A few pics:
…and fits the McModule like a bum in a bucket....
If I can find the time to do beam shots, I'll add to the post.
Chris
The parts:
PM6 host.
McModule.
1 X 17650 Li-Ion.
Clickie.
Mineral glass lens.
The results:
Input = 3.6V, 2.05A
A few pics:
Chris
