I've been offered a UK version of the yellow laser pointer for evaluation purposes. It supposedly outputs <1mW at 593.5nm, to comply with UK regulations, so it won't be of any contest to any of my green laser pointers, except for maybe the pulsed one (a GLP-4 that outputs ~1.6 milliwatts).
Since it's coming from the UK, and is expected to be there in about 1 month, figure late September at the earliest for me to receive one. When I do receive it, it'll almost certainly receive its own web page, which I'll post the URL to in this thread.
(Edit 8:36pm PDT)
Yes, it will be receiving its own web page.
I've actually gotten it started, but of course, not yet published. /ubbthreads/images/graemlins/smile.gif
Some of the text on the page will go something like this:
Yellow beam lasers in pointer format have not existed - until now, anyway.
This is a yellow beam laser pointer, emitting just under 1 milliwatt of laser radiation at 593.5nm; just a hair longer in wavelength than the sodium line at 589.2nm.
It uses a mechanism similar to that used by green laser pointers: an infrared laser diode is fired into a crystal of material that lases at a longer wavelength in the infrared, who's light is then fired into a frequency-doubling crystal, producing the yellow laser beam you see.
This is known as DPSS (Diode Pumped Solid State).
The output power level is this low (less than 1mW) so the laser complies with UK (United Kingdom) regulations regarding laser pointers available to the general public in that country.
This laser pointer is CDRH Class II.
