And here it is in a CNC Dan's CNC123 w/RAM tailswitch:
Here it is disassembled:
Left to right:
Bezel
Lens
O-ring
Fraen Low Profile Optic
Head
MiniPro Pill (small retaining o-ring not shown)
Battery Tube
BatteryStation CR123
Tailguard (RAM switch already screwed inside)
Gives a real run for the LGI's (and "other" similar items') money in the brightness department, too:
Yup, nearly 900 lux, so now to figure out a way to fit an IMS 20.5mm reflector in there: 1000-plus lux, here we come!
If you're going to use this setup, cutting down the rim of the CNC123 tailguard would make for an even shorter light (~1/4" to 1/2") since the RAM button is set so far in.
This Pill simply rocks... /ubbthreads/images/graemlins/buttrock.gif /ubbthreads/images/graemlins/buttrock.gif /ubbthreads/images/graemlins/buttrock.gif
Left to right:
Bezel
Lens
O-ring
Head
Battery Tube
