dedsqwirl
Here is a little project that I was thinking about.
You can run a Diesel on waste vegetable oil (greasecar.com).
I haven't done this yet but was thinking of getting into it. Diesel and waste vegetable oil can have algae/bacteria growth. This will clog filters and ruin injection pumps.
There are air quality filters, medical sterization equipment and water purifiers that use UV light. So I wanted to install a UV light inside the fuel tank because it wouldn't hurt the environment like a biocide additive would.
1. Does anyone know of a somewhat compact germical light fixture that would fit into a fuel tank and handle 170 degrees
2. Should be long lasting 2-3 years
3. Run of 12 volts
4. It could be led, incadescent, fluorescent
5. It has to be Waterproof
6. Is there a Germicial LED that emits at around 254nm
If anyone could post links or information it would be helpful.
-Thanks
3. Run of 12 volts
-Thanks
