I've been trying to find the highest capacity AA battery that will run a WA 1185 which draws 3.15A nominally. It'd be nice to have a little buffer built in, so a battery that will provide at least 4A continuous current would be ideal.
On Supreme Power's website, I found this datasheet for their upcoming 2500mAh AA batteries. Their main website is (http://www.supremebattery.net/).
The sheet claims a maximum continuous discharge current of 7.5A, and momentary (1 second) bursts up to 25A. Is this even possible, or am I misreading the sheet? This would seem to be too good to be true. Now, it doesn't state how much the voltage would sag, but 3.15A is less than half the rated maximum continuous current.
The datasheet for their 1800mAh batteries, here, show a max continuous discharge of only 1.8A, which is more in line with consumer AA batteries.
More data:
2300mAh datasheet - Claims max continuous 6.9A
2100mAh datasheet - Claims max continuous 6.3A
Any thoughts on this?
More data:
