twentysixtwo
I've been playing around with D1S and D2S bulbs in my THOR. Great mod, gives you maybe 10-20% more light with better color and about triple the run time.
You can buy an adapter at Casper's electronics for $25, cut the glare shield off it and put a couple of o-rings on it to get the right spacing, but that's still a less than elegant solution.
I've been playing around with the focus and have taken some careful measurements as to what the adapter should be. Basically, with a D1S you want the metal base to be about 2 mm from the back collar of the THOR reflector. If you mount it flush, the focus is close, but not perfect.
A stepped collar would be nicer and more secure but a simple collar would be enough.
Easy to make.......if you have a lathe. If I supply the dimensions, is there someone out there who is willing to make a batch and sell them to CPF'ers?
