IsaacHayes
What if you were to take 12 NiMH AA's, wire in series = 14.4 votls. Now take that pack and x 3. You get ~ 6ahr. If you used 4, you'd have 8ahr.
This wouldn't be that expensive, and you'd have 14.4 (bright!) correct voltage, and close to same runtime as the stock battery. Would this be able to be charged with the stock charger?
Just an idea, but it' would be a simple non-brainer to get the "correct" voltage to the bulb.
Would this work, or be a bad idea???
