Well, if you don't use it a LOT and runtime isn't as important as brightness, if you unscrew the head a few turns, you can cram 4 C cells in there and run a 3 cell Mag Krypton bulb to very nice effect.
Or for a bit more whiteness but a bit less output, you can of course stick a 4 cell Xenon bulb in with the 4 C cells.
A red 3D Mag with 4 C Cells and a 4 cell Xenon bulb and a sputtered reflector is my large car light.
I've never had good luck with driving 2 cell bulbs with 3 cells. Even when fairly discharged. I did have one old Mag bulb with the green little thingy (technical term) from about a 10 year old Maglite that ran on 3 fresh cells for several weeks of off and on use. I've never been able to find the exact same looking bulbs again. It was quite bright while it lasted though.
