Technician
Hi all, I just got a BB500 NG with the reflector, for a 2AA minimag. Following the instructions for installing the reflector EXACTLY will not allow me to center the reflector perfectly. It always seems to move slightly to one side. The beam is uneffected, but when you look at the reflector, you can tell that part of it is being overlapped by the smaller O-ring.
When I remove the smaller inner O-ring, everything lines up perfectly and works much better. So I ask, do I absolutely have to have this smaller O ring installed in the maglite? It seems to work better without it, but I just want to make sure that i'm not unknowingly hurting anything.
Thanks!
Thanks!
