andrewwynn
Ok.. i totally 'got the bug'.. i played with a maxabeam and it is just waaayy tooo much fun. I recalled aquiring a 3000W arc lamp bulb used for movie projection a while back... and sourced the reflector and bulb socket..
What i need is a power supply.. an igniter and a container with some SERIOUS cooling.
From what my research so far has shown.. the lamp is happiest on pure DC between 24 and 30V.. I have a feeling that i could achieve a near constant current from the painfully easy solution of a number of lead-acid cells in series.. of course very large ones since the bulb runs on 80 to 100A.
i have the technology to make the igniter if i have to.. i have to find out the voltage requirements of the ignition, and it would be great to find out the specs exactly are but i'm pretty sure that it's just pure DC and LOTS of it once it starts.. i know it uses a very powerful magnet to stabilize the arc but i have that covered also.
anybody make something like this on CPF?.. i'm normally in the 'tiny and bright' business, but something is somewhat awe-inspiring about 80,000 lumens in an 18" reflector.. if i had to bet.. it would be able to produce on the order of 50 lumens at 1 mile.
oh.. the nickname right now is 'oscarbeam' because the only suitable pre-fab container i could find to build it into was a galvanized trash can..
safety considerations include UV-filter glass.. and 1/4" plate glass lens.. tortuurous path for the massive air-flow required to cool 3000W.. so there would be no chance to directly view the bulb.
In any event.. the bulb alone is probably worth $800.. cost me zero, so i want to put it to CPF good use.. is there a record out there for how many lumens in a portable light?
-awr
-awr
