Need advice for a power supply for a Triton
.308
Brentwood, TN
What is a good power supply/source (a good buy) for a triton? I've searched around but have no idea what can fill the bill. I found a tripp lite pr15 DC power supply 13.8v 15A for $78. Thanks in advance.
Chris
.308
wquiles
Texas, USA, Earth
The cheapest is an used laptop PS - any unit that provides 12-15 volts DC, usually at a couple of amps, will work great. That is how I power my Triton /ubbthreads/images/graemlins/wink.gif
Will
cy
USA
I use a 12V car battery, then charge up once a month.
wasBlinded
Oklahoma
I use a Radio Shack 12v/3amp unit. That still provides plenty of charging wattage and handles all of my charging needs at relatively low cost.
You can also convert a desktop PC power supply to do the trick, which is probably the cheapest option since many old PCs are basically just thrown away.
cy
USA
got a 15amp radio shak powersupply that will not work with triton.
voltages veri at my house for some reason. I've also got 220 three phase power, which is unusual for a home. at least around here.
triton is pretty sensitive to voltage spikes. hince the use of a car battery for a power source. have not tried a PC power supply because car battery is working well.
marcspar
CT
Cy,
How did you make that clamp charger "thingy"?
That's exactly what I need as I have heard my plan of using magnets to attach various size batteries to my triton has some drawbacks.
Thanks,
Marc
Foxx510
Australia
I use a PC powersupply with my Supernova charger. Works a treat and very cheap. You need to join a few wires on the motherboard connector to make it start up, let me know if you want details.
