I just picked up a PT Yukon last weekend at an REI used gear sale. I knew when I bought it that there must have been something wrong with it, but for $10 I figured I'd take a chance and try and fix it.
When I first got it, only 1 of the 3 LED's worked, and it seemed to flicker a little. I thought there must be a bad connection somewhere, so I was able to open the case and probe around. Somewhere along the way the third LED stopped working. After playing around with it, it seem that all 3 LED's are dead, the incandescent bulb is the only light still working. The switch, the circuit board, all the connections tested fine. After desoldering the LED's and testing them, it confirms my suspicion that the LED's themselves have burned out. There's no circuit driving them, it's just a direct drive off 3 AA's with a resistor in series with each LED.
I found it ironic that I thought the LED's would be the most reliable part of the light, but in fact that ALL 3 of them failed at some point, all the while the bulbs shines brightly. I believe it's still the original bulb too. I just thought I'd mention this fact before people start putting too much faith in any one type of technology, because no matter how reliable you think it is, there's always a chance for failure.
