trivergata
I fianlly finished a multi-week project - ARC LS body (thanks CY), Flupic (thanks Goldserve)and tritium (thanks Vaism)
Also, special thanks to Mini-Modder for the help and parts!
So here we go - First is the heatsinc I made to drop into a threaded retaining ring - it has a small raised area for the emitter, and an angle to drop into the ring. The two holes are for the emitter leads:
Next the Flupic with the leads soldered on. I scraped off some of the coating on the board so it would ground thry the top to my can (it was all pretty when it came from Goldserve, but it needed my personal touch!):
Add some epoxy:
Clamp it together:
Add an emitter (TWOJ - Thanks PhotonFanatic):
Solder the leads:
And add 4 tritium:
That's all, folks! This guy really rocks! The interface is good, the body is and ARC (nuff said) and the tritium adds a cool touch. I have both the 123 clickie and the 2xAA bodies, although it is dimmer on AA's.
Josh
Add some epoxy:
Clamp it together:
Solder the leads:
And add 4 tritium:
Josh
