Delvance
Hello all,
Just a quick report to let people know what's going on with the various lamps CPF'ers use in their 2 x Li-ion lights. I've finally managed to obtain a sample of each and here are my observations, but first off - the lamps.
Wolf-Eyes D26 9V lamp is indeed the brightest of them all (according to my eye and lightbox) and Wolf-Eyes gives this LA a rating of 200 bulb lumens. However, the colour is not as white as the other three imho. The lamp gives off a very big hotspot/blob of light and outside of the hotspot, there are visible rings/artifacts. It's more of a flood lamp, i can't imagine this one throwing too far. However, target ID with this bulb at short/medium ranges is excellent.
Digilight DRB 9V HP 1.2A* is essentially a rebranded G&P G90 HP afaiw and these are rated at 175 bulb lumens. However, there's nothing wrong with it...it manages a fairly large hotspot and it also throws quite well and has pretty big output too. My lightbox and eyes tell me the Wolf-Eyes D26 is only ever so slightly brighter. Once focused properly, this LA is a decent thrower. It's also the whitest (to my eye) of all four bulbs.
Digilight DRB 9V HP 0.8A...eeh what can i say except i'm dissappointed ? Very dissappointed ? Digilight rates this LA at 175 bulb lumens just like the 1.2A draw LA however this lamp produces nowhere near as much light as the 1.2A version. The hotspot is the smallest of all four LAs, it's whiteness seems a little less to the 1.2A LA and it doesn't throw as far as the 1.2A version either. Now i know why some people using this LA are a bit underwhelmed by it- small hotspot, ok throw, and small output. In fact, out of all four LAs, my eyes and lightbox confirms this LA to be the lowest in output, by a good margin.
G&P G90** normal (ie. not HP/high pressure). This LA draws 1.2A much like it's cousin, the HP model. The bulb lumen rating of this LA is 105, however i find this very convervative- if i had to give it a value myself, i would say ~150. It is the greatest thrower of all my lamps by a good margin (i have been able to get over 10,000 lux on two fresh R123s...fantastic for a 2 cell pocket light and a 1.25" bezel), and it creates a decent sized hotspot, the beam is almost as white as my DRB 9V HP 1.2A LA.
*This particular LA has been compared against a P90 running 3xCR123s and the DRB 9V HP 1.2A LA beat the P90 hands down.
**I assembled a pocket rocket G2 for my mate awhile utilising the G90 LA, which was purchased from lighthound. Apparently, he has a freak bulb. Somehow, his G2 with G90 on 2 R123s manages to beat my DRB 9V HP... and i mean totally clobbering it. In fact, it's putting out even more light than the WE D26 LA by far. I should probably measure the current drawn from this particular LA sometime...
Hopefully this info will help future purchases. If anyone would like anymore info on the above 4 LAs, just ask .
- Digilight DRB 9V HP 1.2A draw (AKA G&P G90 High Pressure)
- Digilight DRB 9V HP 0.8A draw (Not G&P rebranded afaiw, Digilight's own product)
- G&P G90 Low pressure (The normal G90 ie)
- Wolf-Eyes D26 9V (new 200 lumen model)
