abvidledUK
Very easy mod to do, replacing standard Elly led with Cree / Seoul star, both as supplied by Dealextreme.
Only thing to watch out for, negative wire also needs to wrap around holding screw, or be soldered to underside of Cree / Seoul Star.
The mod produces brighter light, and also a tighter spot, with no height modification at all with CREE Star.
With the Seoul, I had to unscrew the Elly reflector head approx 1.25 turns to get best spot & focus, as the Seoul sits higher when mounted in the Elly.
The head is thus very loose, and was held with tape for testing.
With the head tightened up against the body, Seoul was floody.
The original led mount is not thermal mounted to housing, I thermal pasted Cree / Seoul Star to housing, after confirming working ok.
Used 2,000 mah nimh AA's for rt's.
Initial measurements...
Original Elly LED:
Current to LED 130ma, current from battery 650ma
Cree'd Elly:
Current to LED 250ma, current from battery 1,100ma
SSC Seoul'd Elly:
Current to LED 230ma, current from battery 920ma
This pretty much is what you'd expect, approx twice the current, for twice (or more) the output.
Output approx two stops brighter for most of the 120 mins RT with Cree.
Similar for 180 mins of Seoul.
So CREE, higher curent, higher output, lower RT than Seoul.
A very welcome mod.
Two interesting details.
The CREE runs brighter, for similar duration as original Elly.
The Seoul runs brighter, for longer than original Elly.
The Cree'd Elly gets slightly warmer, but not so you'd really notice. Lukewarm.
Seoul, not really warm at all.
I also encountered the low voltage "problem" when turning torch on again.
When at low output, after 2/3 hours, the torch would not switch on again, with the depleted battery, at around 0.9v.
No problem really, down to electronics I suspect, battery exhausted anyway.
As usual, lightmeter reading are EV's (Exposure Values) with a reading of 8 being what I consider minimum useful illumination level
Horizontal X axis in 30 minute grads.
