whc
Just got my Lumapower M3-Transformer today, awsome little EDC flashlight.
Nice HAIII finish, no flaws. 2 tailcaps is included, one tacitcal and another 2-stage reverse clicky, nice I think.
As the name says, this little flashlight can "transform", meaning that it can use diffrent batteries with the included batteri tubes (1xCR123A, 1xAA, 2xAA) + it can use a tactically switch or reverse clicky.
A punch is included, that can not only hold the flashlight, but also a battery (2xCR123A, or 1xAA).
The beam of the M3 is very smooth of a XR-E based flashlight, it has an OP-Reflector, that really almost iliminates the dark ring issue (not total though).
Now to the pictures ...
From left: M1, LP-Mini, M3, L1D-CE, T5
And now to some beamshots, all flashlights is running on Li-Ion 1x3.7v battery, the beamshots is about 1m from the wall, all on high.
Left: Fenix L1D-CE, Right: Lumapower M3
Left: Fenix L1D-CE, Right: Lumapower M3, 2-Stops underexposed
Left: Lumapower LP-Mini, Right: Lumapower M3
Left: Lumapower LP-Mini, Right: Lumapower M3, 2-Stops underexposed
Left: Lumapower M1, Right: Lumapower M3
Left: Lumapower M1, Right: Lumapower M3, 2-Stops underexposed
Left: Amilite T5, Right: Lumapower M3
Left: Amilite T5, Right: Lumapower M3, 2-Stops underexposed
Update: Beam shots with various batteries and in flood mode
Update: More beam shots on distance of 12-14m vs various flashlights
Update: Here is the size of the M3 in numbers, and compared to other in its class:
Lumapower M3:
Length: CR123A body: 9.7cm, 1xAA body: 11.2cm, 2xAA body: 16.1cm
Diameter: Head: 2.2cm, Body: 2.2cm, Tailcap: 2.2cm
Fenix L1D-C:
Length: 9.6cm
Diameter: Head: 2.1cm, Body: 1.8-2.0cm, Tailcap: 2.0cm
Amilite T5:
Length: 9.2cm
Diameter: Head: 2.4cm, Body: 2.0cm, Tailcap: 2.0cm
Update: Some runtime tests.
Runtime on High with AW's protected 3.7v high current 750mah RCR123A cell: 1hour 9min 56sec
Runtime on High with AW's protected 3.7v 750mah 14500 cell: 1hour 28min 59sec
Runtime on High with 1xAA Ni-Mh 2600mah cell:
2hour 25min 22sec to dead
After about 1hour 30min the flashlight dimmed to half brightness
From 1hour 3min to 2hours and more the flashlight was even more dim, but with useful light
After 2hours the flashlight quickly went dead and was very dim
Runtime on High with 2xAA Ni-Mh 2600mah cells:
3hour 22min 37sec to dead
After about 2hours the brightness dimmed to half
From 2hours to 3hours the flashlight was even more dim, but with useful light
Over 3hours the flashlight still produced some light, but quickly went dead
Update: Some more beam shots comparing the M3 to L1D-CE on Ni-Mh
Update: Here is some results of Overall Output in Lux:
Lumapower M3:
1xAA on high: 3640 Lux
2xAA on high: 4300 Lux
1x14500 on high: 5880 Lux
1xRCR123A on high: 4390 Lux
Now just to compare:
Amilite T5:
1xRCR123A 3.0v on high: 8340 Lux
1xRCR123A 3.7v on high: 10910 Lux
Lumapower M1:
1x18650 XR-E OP: 8140 Lux
2xRCR123A 3.7v XR-E OP: 8950 Lux
1x18650 SSC P4 OP: 5540 Lux
2xRCR123A 3.7v SSC P4 OP: 8230 Lux
Lumapower LP-Mini:
1xRCR123A 3.7v OP: 7810 Lux
Fenix L1D-CE:
1xAA on high: 3990 Lux
1x14500 on high: 8240 Lux
Led-Lenser Hokus Fokus:
3xAAA Ni-Mh: 4850 Lux
Ultrafire WF-500L:
2x18650 3.7v: 4660 Lux
Nuwai X-3:
2xAA Ni-Mh: 3020 Lux
Lumapower M3:
Fenix L1D-C:
Length: 9.6cm
Amilite T5:
Length: 9.2cm
Lumapower M3:
Amilite T5:
Lumapower M1:
Lumapower LP-Mini:
Fenix L1D-CE:
Ultrafire WF-500L:
Nuwai X-3:
