rockz4532
i got my E01 today, and i noticed it has no lens! the bezel has a small opening around the LED. Is this waterproof, if so to how many feet?
Where are you getting your 100ft from, Marduke? Its late and I'm tired, but I seem to remember Fenix rating it as "waterproof to IPX8 standards." I don't believe thats terribly descriptive (at least, going on memory again, from the last time this type of question came up about fenix)
Is the LD01 and LOD just as waterproof as the EO1 and Arc?
Thanks.
I wouldn't try it but it should be fine in a little bit of water.Is the LD01 and LOD just as waterproof as the EO1 and Arc?
Thanks.
It has the same basic seal construction of the Fenix E0 and Arc AAA, both waterproof to 100+ ft. And the E01 is more robustly made and durable than either, so....
I've had many AAA Arc's and like my E01's but where did you get that information? I recall Arc AAA's being photographed in a dive but am not aware of any information or tests on the E01.
Everything about it's construction is more robust and durable. Anodized non-conductive vs non-anodized conductive threads, spring vs battery crusher design, thicker side walls, deeper reflector to protect the LED from damage, and an O-ring that is always engaged when in the off position unlike some examples I have seen from Arc.
Half exposed o-rings tend to not be as water resistant or durable over time.
So it's more personal opinion rather than testing. I see. Thank you for your response.
Well, those are not really personal opinions, as those design elements are factually more durable by design.
Also, the 5 story drop test favors the E01, as the Arc would not turn on after.
