NeSSuS-GTE
I was so intrigued by AWs IMR 26500s and so many new bulb possibilities. I decided to try a Mag 4D platform running Five 26500s at roughly 21v off the charger.
High output bulb options in this range were more limited than I expected. I really liked the 64458. It has a beautiful hot spot and pushes very hard at ~21v. But what else is out there? Anything exotic to experiment with?
Welcome: GE HI-111 19.7v 200w
This bulb is presumably used for swimming pool light boxes. Interesting...
Lets check it out.
Installing into the Mag with the MR16 reflector yields huge output and gets HOT, but the beam has a big hole in the center.
So I guess I have to get that bulb out of there.
Cool filament configuration.
Filament CLOSE-UP
Painstakingly removed from reflector potting compound and installed in Mag.
What can I say, it works pretty well.... ITS BRIGHT!!!!
The beam pattern leans a lot more towards flood. (I will add some beamshots later.)
Is it somehow better than an overdriven 64458?
I tend to believe this is throwing more energy out there. I can tell a difference in the heat alone. When it comes to the beam its hard to compare. They are both so overwhelmingly bright. Until I take some beam shots for a more objective comparison, I'll just call it a draw. AND a Successful and Fun experiment. :thumbsup:
Lets check it out.
Filament CLOSE-UP
