As many of you know, Nitecore recently released their new 4xAA light, the EA4 Pioneer.
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111574%2Fd84c62e.jpg&hash=76807c8434c7a93ca99bb87924287f76)
Unfortunately, we've had many reports of a failure of the switch cover. Apparently, when left in the car on a hot day, several members have returned to find the switch cover bubbled out or cracked. You can reference some of the reports here:
http://www.candlepowerforums.com/vb...ed-Switch-Cover-on-Nitecore-EA4-Pix-Questions
http://www.candlepowerforums.com/vb...e-EA4-Ballooned-Melted-switch-Repair-Write-Up
http://www.candlepowerforums.com/vb...and-finish-flaws-(take-your-poll-here-)/page3
In response to this, Nitecore has started using a new switch material that should fix this problem. They sent me a sample EA4 with this new material, and told me the old material was TPR (I'm guessing thermoplastic rubber), and has been replaced by a silica material that can stand up to 200 degrees C. They've asked me to test it out, and post the results here.
So, I'll start with the appearance of the switch cover before testing.
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111564%2Fbc815eb.jpg&hash=e9675e284c203233cd009317082913c3)
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111568%2Fb0804ee.jpg&hash=085547cb2aa5c629efcf8a36fe6fd55b)
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111565%2F14b1226.jpg&hash=b4fcdbc4a37328c6b0f0fd994ec8f482)
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111566%2F62cba76.jpg&hash=e9dd55e0b512a975be489ffd5573da8d)
There is a blue LED indicator light that flashes underneath the switch cover so that the blue shines through. Here is a picture:
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111567%2F90856bb.jpg&hash=9a449a84d18947737cfe6453979885ac)
And here is a short video:
So, on to the testing. From what I've read, it seems the trouble happens when a person leaves the EA4 in an area where it's exposed to temperatures significantly above room temperature, most often in a closed car on a hot day (temperatures in there can reach 100 - 125 F pretty easily). This is pretty hot, but shouldn't cause trouble for a high-end flashlight.
There is much speculation about what exactly causes the deformation of the switch cover. Here seem to be the main ideas:
-The heat softens the material and causes it to deform
-The change in temperature of the air inside the battery compartment causes it to raise in pressure, pushing out on the switch cover and causes it to deform
-The batteries in the battery compartment heat up and vent gas, causing a raise in pressure that pushes out on the switch cover and causes it to deform
-A combination of these factors
I think it's most likely a combination of these factors - the heat softened the material, and the rise in pressure inside the battery compartment pushed out on the now softened material. To test the new material, I'll try each of these in stages. I'll post the results as I go along.
Day One
For the first test, I left the EA4 in a hot car all day, with the battery cap removed so that no pressure would build up inside the battery compartment. (I placed it in an open contained to contain any mess
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1111539%2F6f492b3.jpg&hash=cee5f3ca21499765867f51ed8a7cc758)
I don't have a way to measure the temperature inside the car, but it was very hot. About as hot as you expect a car to get on a hot day, or maybe a bit hotter. At the end of the day, I don't see any flaws in the switch cover.
Day Two
For the second test, I will leave the light in the car with the battery cap on, but no batteries in the light so that there is no possibility of gas venting from batteries. I will leave the light out of direct sunlight, so only heat from the air warms up the light.
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1122177%2F7b2fcb3.jpg&hash=1e6705be7ce5ab4fa035b1970ea81366)
At the end of the day, I can't find any flaws in the switch cover material.
Day Three
For this test, I will leave the light in the car with the battery cap on, but no batteries in the light so that there is no possibility of gas venting from batteries. I will leave the light in direct sunlight, so the air inside the battery compartment will be heating faster than that outside.
![](/proxy.php?image=http%3A%2F%2Fjust.razzi.me%2Fphotos%2F1122176%2F0db0c58.jpg&hash=1eaa4661cd44bfd4f7c1d36af93dee6a)
After the test I still couldn't see any damage to the switch cover.
Day Four
For this test, I will leave the light in the car with batteries in the compartment and the cap closed, using high quality NiMH batteries (little chance of gas venting).
(no picture)
At the end of the day, no change in the appearance of the switch cover material, it looks still in great condition.
Day Five
For this test, I will leave the light in the car with batteries in the compartment and the cap closed, using low quality alkaline batteries (higher chance of gas venting).
(no pictured)
At the end of the day, no change in appearance or performance. I filled up the sink and left it underwater for a while, no sign of watering entering so it seems to have maintained it's waterproofness.
As of now, this test is considered compete.
I'll be leaving the EA4 in my car as an emergency light, so it will be exposed to high heat for the rest of the summer. If you don't hear anything, assume no change in appearance or function.
Conclusions
I haven't heard from Nitecore how they plan to handle the situation for those who have had a failure of their switch cover, or for those who have the old switch cover material but no failure yet.
EDIT 13 Aug 2013:
<I've asked Nitecore which serial numbers have the old and new switch material, and how they're handling the situation for those who have the old, and I received the following response:
So, if your serial number starts with 307 you're safe, if not then you might have the old material. It's hard to tell just looking at the pictures, but the new material is slightly less transparent and slightly grayer. If I can get a good side by side comparison picture I'll post it here. If you've got something that's not a 307 and you're unsure, you can contact Nitecore at that email address with your serial number and they should be able to look up which material it has. >
EDIT 31 Aug 2013:
<The EA4 has passed all my tests, no discernible effects to the switch. I'll leave it in my car to continue to expose it to heat over time, but if you don't hear anything, that means there have been no problems. All that remains is to see Nitecore follow through on the replacement of faulty units, so if you have any stories on the outcome of your communications with Nitecore please share.>
Day One
Day Two
Day Three
Day Four
(no picture)
Day Five
(no pictured)
Conclusions
EDIT 13 Aug 2013:
Nitecore Marketing said:All the serial number begins with 307 (July 2013) are 100% renew the new material, the product gets in the market before July might be using the old material, but not all of them.
We will be happy to replace all the faulty material products, customers will only need to contact the dealer where they purchased, or email our customer service: [email protected], they will get a new EA4 for free.
Nitecore does not suggest users repairing their lights their own.
EDIT 31 Aug 2013:
