Reviewer's Note: I am very backlogged with lights, so expect less detail than typical in my upcoming reviews. I will prioritize results over text for the next little while.
The Moon RC2 is a rechargeable flood light from Xtar. Featuring a very unique design, this could be seen as replacement for a headlamp – and one that you would wear on your belt, or clipped to a vest.
The packaging is a small box with specs print on the outside. Included inside the light, micro USB cable, manual card, warranty card.
Xtar also included a small collapsible fanny-pouch for my assessment:
A cute design, it would allow you to stash the light, or a small cell phone. Note that some of the newer, larger cell phones wouldn't fit in the waist pouch.
And now, back to light ...
For comparisons of the Moon below, I have chosen some of my recent headlamps. All dimensions directly measured, without battery installed (unless stated otherwise):
Moon RC2 (battery included): Weight: 89.7g, Length: 84.1mm, Width: 54.7mm
Fenix HP30: Head unit alone: 99g, Head unit with diffuser, head strap and wire: 169g, Battery compartment alone: 129.4g, Battery compartment with 18650 batteries 219g, complete unit (with headband, compartment and batteries): 388g
Nitecore HC50: Weight 85.4g, Length: 86.0mm, Width (widest) 36.4mm
Olight H15S Wave: (1xLi-ion, 4xAAA): Head alone: 42.2g, Battery compartment alone: 31.0g, Battery compartment alone with OPS-H15S Li-ion battery: 58.3g, Battery compartment alone with 4xAAA: 77.3g, complete unit (with basic headband and Li-ion battery): 118.1g
Petzl Tikka XP2 (3xAAA): Weight: 52.3g, 88.4g with batteries
Skilhunt H02: Weight: 61.3g, Length: 110.8mm, Width (widest): 28.0mm
Spark ST5 (1xAA): Weight, 41.5g, Length 58.4mm, Width 42.8mm (max body), Width 24.0mm (bezel)
Zebralight H31w (1xCR123A): Weight: 28.6g, Length 66.9mm, Width (bezel) 22.1mm.
My sample of this egg-shaped unit was well made, with no obvious defects or damage. It comes in either blue or gray as the accent color. There is a larger diffuser cover that distributes the light evenly. As a result of the design, output is angled slightly downward in use (when carrying with switch button up).
There is a robust pocket clip on the back, which held on securely in my testing. Thanks to this large clip, light can headstand and sidestand on a flat surface (as well as on its back, of course).
The electronic button is easy to access on the top of the unit. Note there is a red and green LED under the button that indicates charging status, or when the battery is running down. The button lights up green in normal operation when on, and switches to red when the battery is almost drained (<45 mins remaining, according to Xtar). At <15 mins remaining, it starts to slowly flash red (again according to Xtar, I have not verified exact times). See below for the user interface.
Under the side-mounted rubber dust cover on the side is a standard micro USB port (cable included). When plugged in and charging, the LED under the switch lights up red (charging) or green (fully charged). Scroll down for charging times.
Beam was neutral white tinted on my sample, and very even (i.e., no hotspot, pure flood). The diffuser is not removable.
Click the electronic switch to turn on.
There are four main output levels controlled by a subsequent click of the switch. Mode sequence is Lo > Hi > Med > Moonlight > Off, in a repeating loop. Note that there is no mode memory, and it always activates in this sequence.
To access Strobe, press and hold switch for ~1.5 secs (from either on or off). To turn off, click the switch.
Note that this means that if you want to turn the light off, you need to either cycle through ALL the constant output modes, or activate Strobe first. There is no other way to turn the unit off. :shakehead
The light can be activated while charging.
Video:
For information on the light - including the build and user interface - please see my video overview:
PWM/Strobe
As promised, the Moon RC2 is flicker-free – there no indication of pulse width modulation on any level, and I presume it is current-controlled. :thumbsup:
Strobe:
A fast tactical Strobe mode is included (20 Hz). I don't see the point of this personally, and would have recommended a slow signaling strobe instead.
Standby Drain
As the switch is electronic in a nature, a standby current drain is always present. As the battery unit is not user-accessible, I cannot measure this. There is no lockout mode that I can see.
In-Light Charging
Because the light uses a USB charging cable, I was able to take direct measures of the charging parameters using my Xtar VI01 "USB Detector" (basically a specialized USB current/voltage meter). There are many of these on the market now, and this model was favorably reviewed by HKJ here.
Using a 2A-rated AC charger, initial charging current was measured at 0.97A (5.32V input voltage).
This rose slightly to 1.02A (5.34V) over the next 2.5 hours, at which point it started to drop slightly.
At 3hrs, the charging was at 0.93A (5.34V).
By 3hrs 20mins, charging was at 0.63A (5.32V).
By 3hrs 40mins, charging was at 0.21A (5.30V).
By 3hrs 50mins, charging had terminated 0.0A (5.09V).
The LED switch light changes from red to green once termination occurs. This is a good charging algorithm and charge time. Note it will take longer if you are using a 0.5A rated USB port for charging.
Beamshots
For white-wall beamshots below, all lights are on Max output on their respective battery source. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
You can't really tell much from these standard distance beamshots. The Moon is a full flood light, whereas the other headlamps all have reflectors or optics for focused throw (with some level of diffusion on top). This makes the Moon quite distinctive in my testing.
Scroll down for actual beam distance and output measures.
Throw/Output Summary Charts:
As you can see, there is no real "throw" for this light - it is a full flood, all around the unit.
Here are the lumen estimates for all levels:
It has a range of outputs, although I wish Moonlight and Lo were lower. And of course, I would prefer a different mode sequence (see discussion below).
Runtimes
All my runtimes are now done on 3100mAh 185650, which is not very fair for comparison. Most of my headlamps are AA/AAA-based, so that doesn't work well either. Instead, I am using below older flashlight data for comparison, based on AW 18650 protected 2200mAh cells (as the capacity rating is equivalent). All runtimes are done under a cooling fan.
It is hard to provide accurate output measures for flood lights (and of course, you lose a fair amount of efficiency due to the diffuser). But it is probably fair to say that the Moon is not quite as efficient as typical light on 2200mAh. That said, it shows very stable flat-regulated output at all levels. It also seems to match the specs reasonably well.
The main issue is the user interface: it has a very inconvenient order (i.e., Lo > Hi > Med > Moonlight), and you CANNOT turn it off without first going through ALL the modes (or through strobe first).
Strobe is a very distracting tactical strobe (i.e., 20 Hz), instead of a more useful slow signaling one.
The light is designed to be carried on a belt, or on strap/vest pocket around the chest – it is not meant to be used a headlamp (although could attach to a headband if necessary).
It is a flood light only (i.e., only diffused output).
As with all lights with electronic switches, the Moon requires a small stand-by current (that I cannot measure).
Accidental activation is always a potential concern with electronic switches. There is no lockout mode that I can see.
Lacks a true "moonlight" mode.
I was intrigued by the design of the Moon RC2 – this is the first time I've seen a dedicated flood light meant to be worn at waist or chest level (instead of the more typical headlamp). :ooo:
When worn on a belt, it actually works very well for walking around at night. It shines a lot of light at your feet, and doesn't produce the usual upper-level reflections/distractions that headlamps can cause (especially for those of us who wear glasses). The unit seems well designed, and can be angled in a number of ways on a flat surface, or hung from a height, increasing its versatility.
I like the in-light charging feature, using a standard micro-USB cable. Charging worked well in my testing.
Overall output/runtime efficiency is a bit low (likely due to the use of the diffuser), but with very stable flat-regulated output.
I also like the beam, which is neutral-white tinted, and free of artifacts. The beam is stable - there is no sign of PWM or other flicker, which is a definite bonus. :)
But what mars this light for me is the (frankly) horrible interface. I would MUCH rather have had the light come on in Moonlight mode, and cycle up in output (instead of the current odd Lo > Hi > Med > Moonlight sequence). "Moonlight" should also be lower than the measured 6.5 lumens that I found.
But the major problem is that you HAVE to cycle through all four modes to turn the light off. :thinking: Alternatively, you can go through Strobe first for a more rapid off (i.e., from on, do Strobe > off). This is hardly an improvement though, since they have included a 20Hz fast tactical strobe mode! Again, a much slower signaling strobe (1-3 Hz) would have been far more useful for a general purpose walking light.
I strongly urge Xtar to revise the interface of this model. It really limits the usefulness and functionality of the light to have to go through all outputs modes (in a bizarre sequence) to be able to turn off the light.
As always, I leave it to your judgement as to whether or not you can live with the interface. Aside from these issues, the Moon works as advertised, and seems to be well suited as a portable, rechargeable, novel-carry flood light. The build quality and performance seem impressive for a $20 light. :wave:
Moon RC2 was supplied by Xtar for review
- 5x Samsung 5630 LED (80+ CRI)
- Output/Runtime: High 120 Lumens / 4.2hr – Mid 60 Lumens / 9hr – Low 30 Lumens / 16hr – Moonlight 3 Lumens / 120hr – Strobe 120 Lumens
- Beam Intensity: 57cd
- Beam Distance: 15m
- Built-in rechargeable 2200mAh battery
- Material: ABS+PC
- Power source: 5V/1A
- Charging Port: Micro USB
- Weight: 87.5g
- Size: L82.5mm * W55mm * H45mm
- Impact resistant: 1.5m
- Waterproof: IPX6
- Package contains: Light, USB cable, User Manual, Warranty Card
- MSRP: ~$20
Video:
PWM/Strobe
Strobe:
Standby Drain
In-Light Charging
Beamshots
Runtimes
