wptski
There was some talk about using this power supply as a better replacement but later it was mentioned that it causes a bit more heat because of the somewhat higher voltage! It was mentioned that maybe it could be adjusted. So, what happened to the suggestion of using this power supply? I got one then but never used for fear of causing a problem!
